Whirlpool washer front load
Old 03-27-20, 04:00 PM
G
my whirlpool washer want pump out the water it tells me a code that I need to check pump.i took the pump off and hooked it up to 120 volts and it didnt do anything. Am I right in saying the pump needs to be replaced
Old 03-27-20, 07:15 PM
Received 2,977 Votes on 2,686 Posts
Welcome to the forums.
I moved your post to it's own thread in the correct forum.
Based on your test..... I would agree the pump is bad.
I will usually go one step further and check the motor for continuity with an ohmmeter.
Old 03-28-20, 03:55 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
You have the pump in hand. Stick your finger in hole and see if you can turn impeller. A lot of time something gets stuck in there.
