Ice Maker drops water into back of freezer and ice container
Old 04-14-20, 09:42 AM
Received 3 Upvotes on 1 Post
Hello all,
I have a model AD-18 ice maker in a top freezer.
The water going into the freezer apparently leaks. This causes water going into the ice cube container and causes a big rock of ice. There is also some frozen water on the back wall of the freezer. I assume there is a water leak and it is dripping into these places and then freezing.
Any idea what the issue might be?
thank you!
Old 04-14-20, 10:04 AM
Received 3,892 Upvotes on 3,489 Posts
If the tray is overfilling and it's frozen where it enter the freezer..... the fill solenoid is leaking.
It could be defective or the supply valve feeding the fridge is plugged or not open all the way.
That type of valve needs full water pressure to close properly.
Old 04-14-20, 10:57 AM
Received 293 Upvotes on 263 Posts
Most ice makers have an adjustable fill volume.
Also the ability to run a test so you can see if it is the tray overfilling.
I am not sure if it will apply to your unit but perhaps the following will help.
The ice maker info starts on Page 46.
https://drive.google.com/file/d/0BzI...JlU0xaTG8/view
Old 04-14-20, 12:00 PM
I don't think the tray is filling as its not making ice. Would it still be a fill solenoid issue?
Old 04-14-20, 12:11 PM
Look at the back wall of the fridge over the ice tray. You should see what looks like a hole and a funnel under that. If that area is iced up.... there is an issue with the solenoid leaking.
Spaceace voted this post useful.
Old 04-14-20, 12:51 PM
Thank you - and it looks like that is part of the water inlet valve?
Old 04-14-20, 02:49 PM
What you see on the back of the fridge over the ice maker is the cold water fill area.
The actual solenoid is down in the bottom of the fridge.
Old 04-15-20, 04:49 AM
A make and model number of the fridge may help.
Old 04-24-20, 09:52 AM
Yes, I'm sure that would be helpful - the label says Electrolux, model FFUI1826MS0.
Thanks again for everyone's help!
Old 04-24-20, 10:05 AM
Here is info on this unit
Frigidaire Manual Search Results
