NEED ADVICE: Bosch Dishwasher door won't stay up
Old 04-27-20, 11:13 AM
T
The door on my Bosch dishwasher (model SHX65T55UC/01) falls down when opened. I presume this is a spring issue, but have no knowledge on how to access or repair. Help much appreciated.
Old 04-27-20, 01:20 PM
P
Received 1,571 Votes on 1,412 Posts
You will have to open up your machine to find the cause. I suspect the spring or cord has broken. They are relatively inexpensive and can be ordered online at Marq1 mentioned.
Old 04-27-20, 01:37 PM
Received 235 Votes on 213 Posts
Undo the dishwasher from the cabinet and pull it forward,
On each side you will see a spring and a cable attached to the hinge.
One or both are probably unhooked or broken.
Go to the Sears parts site.
Search for your model.
Look in the Base assy section.
Parts are 508 and 507.
There is also a roller assy (part 528) but I do not know how that is used.
It should not be difficult to figure out.
Old 05-04-20, 10:05 AM
T
Thanks for your help............................................................!
