Maytag washer stops before rinse cycle
Old 05-27-20, 03:16 PM
F
Hi. My Maytag washer stops ,full of soapy water, just before it reaches the rinse cycle. I can get it to empty the soapy water and let in clean water by clicking it to the next cycle. It seems like it doesn't happen every time. It is model #MAV5000AWQ
Any suggestions?
Old 05-27-20, 05:38 PM
Received 824 Votes on 774 Posts
Can you double check that model number for us ?
Old 05-27-20, 06:10 PM
F
I must have typed it in wrong. It's MAV5000AWQ
Old 05-27-20, 06:25 PM
That's better.
That machine has a standard mechanical timer.
Does the machine go completely dead when it should go to drain and rinse ?
I'm guessing the timer is not moving and is silent too ?
I'm leaning towards a worn out defective timer.
Have you tried other cycles...... like gentle ?
Sears Parts direct - exploded views
Old 05-28-20, 02:57 AM
Received 132 Votes on 123 Posts
The following may be useful to you
https://drive.google.com/file/d/0BzI...k4SXRtMkE/view
Old 05-28-20, 04:06 AM
F
Yes, It goes, completely dead, no noise at all. The timer doesn't move at all. So far I have tried the color and whites cycles and it still happens. I might try delicates after work.
Old 05-28-20, 04:16 AM
F
Thank you for the manual, It will definitely come in handy!
Old 05-28-20, 04:55 AM
pugsl's Avatar
Received 59 Votes on 55 Posts
Before you spend a lot of money on washer is the tub hitting the sides yet? If not you may be ok. If tub hits sides parts are cheap but is a real pain to fix. Sounds like timer I think
Old 05-28-20, 05:16 AM
F
I don't think so. Not 100% sure. During which cycle?
Old 05-29-20, 04:07 AM
pugsl's Avatar
Will happen in spin cycle. Have seen it so bad that washer will walk across the room.
Old 05-29-20, 06:49 AM
F
I will check that out, it definitely doesn't move itself.
Old 05-31-20, 08:04 AM
F
I don't hear the tub hitting the sides.
I'm pretty sure the timer is the problem. , If I pop the knob in and out quickly I can get it to work
