Samsung Stormwash dishwasher won't drain
Old 06-03-20, 09:33 AM
B
I have a Samsung DW80K7050UG that won't drain. Not a new install, no garbage disposal. There is not a lot of repair info online that I can find for this model. I have checked the hose, no apparent clog. No water in the hose. Removed impeller pump, checks good for continuity. I heard it trying to run (pump type noise) after I reset (removed power for 15 minutes and powered back up) but the water was not draining out. I cannot determine if this unit has any type of check valve? The hose off of the impeller pump goes to a plastic tank on the side, not directly to the sink drain. Separate hose comes out of that plastic tank. Any ideas appreciated.
Old 06-03-20, 08:25 PM
Received 841 Votes on 788 Posts
It can be hard to find servicing information.
Have you checked under the kickpanel for a tech sheet ?
Did you try running the pump disconnected from the sump ?
In the link below..... click on the "SUMP" tab.
Part #1 is the drain pump.
Part #2 is a dishwasher diverter motor.
I have a feeling that diverter may be for changing over from wash to drain.
I haven't come across that before.
Sears Parts Direct - exploded views
You can buy a downloadable service manual. It may be worth the $16.99
Service manual
Old 06-04-20, 03:15 AM
Received 135 Votes on 125 Posts
Old 06-04-20, 01:04 PM
That link may not be in the clear. If you can't download it let me know and I can help.
Wow.... a needlessly complicated dishwasher.
