Vacuum Condenser Flashing message
Old 07-04-20, 09:30 AM
I have a Sub-Zero refrigerator / freezer series 632 and the "vacuum condenser" message continues to flash after thoroughly cleaning the condenser with a vacuum. The temperature is held where it needs to be and all else seems to be working normally. What do I need to do to make the system reset the message?
Old 07-04-20, 09:23 PM
Received 923 Votes on 862 Posts
Apparently is not a warning based on time or interval. It is based on compressor run time versus actual temperature. As far as I know if the unit is operating 100%..... then turning it off and then back on will reset that code. Make sure the door is closing and sealing well as that can cause the same problem.
SubZero troubleshooting
Old 07-05-20, 06:10 PM
Thank You!!! We turned off the unit and left it off 10 minutes. That was apparently enough for it to reset itself. Thanks again.
Old 07-05-20, 07:30 PM
Hopefully that will resolve the issue.
