Whirlpool gas stove oven working inconsistently
Old 07-22-20, 09:07 AM
G
I have a Whirlpool gas stove, not sure of the model but it is about 7 years old. In the last week I have had multiple instances where we turned on the oven, it went up to the correct temp (and beeped indicating it had reached temperature), then put in food and set a timer only to come back and find that while the display on the oven was still showing the correct temp, if you turned the oven off and turned it back on the temp had gone back down to around 170° because the burners are not coming on. Today we were trying to make some biscuits and I had to turn it off and back on about 8 times until the oven burner would finally kick on. I can see the igniter glowing when you turn the oven on, it's just not consistently turning on the gas. Stove top itself works fine.
What do I need to look at/replace to fix this?
