Three prong stove outlet
Old 09-19-20, 04:38 PM
H
Tonight there was a buzz, a flash of light and smoke from my range in the middle of making dinner. I'm sure that the range is dead. I unplugged it and flipped the breaker back on and it didn't flip back off, so I'm guessing it was a stove problem not an electrical problem. However, I want to test the outlet to make sure there's no voltage problems etc. What all do I need to check before I go buy a new range, plug it in, and blow it up too?
Should I plug the range back in and see what happens?
Old 09-19-20, 05:03 PM
Received 1,110 Votes on 1,030 Posts
If you have an electric range...... most likely it's a shorted element. I don't recommend plugging it back in to try it but if you do...... turn the breaker off..... put the plug in and turn the breaker back on. You don't want to plug something in with a possible short issue.
Old 09-19-20, 06:28 PM
H
Oven is a Samsung Model #NE59J3421SS. The culprit appears to be a wire on the element. Not sure how expensive/difficult it would be to replace
Old 09-19-20, 07:30 PM
A fairly common problem. The end broke off the element.
It may have been weakened during installation.
The bake element is part # DG47-00038B. You can search using that part number. amazon has them too. Shop around for prices and/or guarantee. It's listed in the "main assembly" tab in the parts views. It's only held in with two screws..... one at each end. If that terminal is damaged.... you may have to crimp on a new one.
Exploded parts views
Please be careful..... unplug the range before working on the element. If you want to use the stove while ordering the element..... the element wire ends must be insulated.
hmhill17 voted this post useful.
Old 09-19-20, 09:14 PM
H
They actually have that part at a place somewhat near me so I may just drive out there Monday morning when they open.
Luckily, I have a gas burner and various other cooking options. Though I'm tempted to plug it in and see what happens with just the stove top.
Old 09-20-20, 02:38 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Before you plug it in be sure to tape that end so it doesn't it something.
Old 09-22-20, 04:34 PM
H
I think I found the problem.
Got the new one today and swapped it out. Took 15-20 minutes. The convection fan stopped working again, so I have a bad feeling about that one.
Thanks @pjmax for all the information and help.
Old 09-22-20, 04:41 PM
Some ranges do seem to have problems with the convection fan failing prematurely.
