Frigidaire FPRH19D7LF1 - where is thermister - help - pic
Old 09-23-20, 01:49 PM
D
I am having large temp swings so wanted to try new thermister prior to control board. Control board looks easy but I don't know where the thermister is. Can anyone help locate? Thanks.
Old 09-23-20, 02:39 PM
Received 1,121 Votes on 1,041 Posts
This is a fridge under the Electrolux badge. There is minimal service data available. Even the tech sheet which is usually very helpful is absolutely useless.
The thermistor is listed as NI (not in diagram) of every parts list I've seen.
I'm fairly certain it's in the cold air flow ducts behind where the temperature is set. The area you have partially pulled down. The control board should be in that same area and the sensor connects to F. F may be a plug on the board.
Tech service sheet
Old 09-23-20, 04:21 PM
D
Thank you for looking it up. I also posted a message on FB and a guy told me it is behind a panel at the bottom of the refrig where the evaporator is (behind bottom drawer). I haven't tried getting that apart yet. That sound reasonable though?
Old 09-23-20, 04:27 PM
I wouldn't discount that location.
Typically there are several sensors and one would be near the evap coil and another in the airflow duct.
I read this....
The thermistor will be located either behind the evaporator cover or in the control housing. I believe it will be mounted to the wall somewhere behind the evaporator cover.
