removeing 12v light bulb pin
Old 10-03-20, 10:43 AM
I have a Dacor double oven and in removing the 12v 20W bulb, one of the pins on the bulb stayed in the socket. How can I get this pin out and then replace the bulb? The socket faces the back of the oven and is difficult to see into.
Old 10-03-20, 10:59 AM
Received 1,118 Votes on 1,038 Posts
If there is enough pin sticking out of the socket.... you could use needle nose pliers to grab it.
If you can't grab it..... the socket will need to be replaced.
Some sockets are mounted to a plate that can be changed from inside the oven.
Post the model number.
Old 10-03-20, 02:09 PM
Thanks. I'll see if I can get the socket out.
