Washing machine not filling
Old 10-04-20, 01:56 PM
Arrow Washing machine not filling
My Whirlpool Washer wasnít filling much. Iím not sure if it ever filled much. Loads would not get submerged at all. I took the back off the machine and looked at the hose that goes to the fill sensor on the control board.
There was a plastic wire inside the sensor tube. It looks like a weed eater string. Itís about 16Ē long.
Is that supposed to be in there?
By the way, im not kidding. The string really was inside the tube.
Old 10-04-20, 01:59 PM
Old 10-04-20, 02:06 PM
Old 10-04-20, 02:57 PM
Received 1,119 Votes on 1,039 Posts
I have never seen anything like that inside the water level sensor fill line.
My forum partner should be thru and he may know.
Anyway..... that water level is calibrated in the control board programming.
In the following tech sheet..... it explains how to relearn the water fill height.
File Type: pdf
Old 10-04-20, 04:24 PM
I removed the plastic wire thing and put it back together. I ran calibration and then ran a clean cycle.
hope it fills enough next weekend when I do laundry again.
Old 10-04-20, 04:26 PM
Cool. Let us know how that goes.
Old 10-04-20, 04:34 PM
I will
thanks for the pdf.
Old 10-05-20, 01:51 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
In all the washers II have taken apart I have never seen a plastic anything stuck in pressure tube. Hope taking it out works. If I remember right pressure sensor is in the control board. Been a while since I have worked on one.
Old 10-05-20, 04:04 AM
Yes. The pressure sensor is in the control board. Iím hoping what I did fixes it.
yíall think maybe a disgruntled employee at Whirlpool? Lol
Old 10-05-20, 04:23 AM
Received 157 Votes on 144 Posts
If the wire is stiff it could be that it is there to stop the pressure hose from kinking.
Note that these units do not add much water to the tub compared to agitator units.
