Signs of Small leak in Clothes Washer + not spinning on rinse
Old 10-05-20, 08:48 AM
biketrax's Avatar
Received 1 Vote on 1 Post
Kenmore Washer Model#26882500 Serial # CS3929978
So we have been noticing a small puddle under the machine not sure about location So I flipped it to 45. I noticed the pump had some rust around it. I also noticed some dust around what I believe is a clutch or transfer to the drive (which may be causing the spin cycling to not always drain/or spin. I went to
e-replacements. I could not get any information on my model #. Before I start to take things apart (being just a small or occasional problem) I really would of like to know that I can get some parts. Any Suggestions? thx
Old 10-25-20, 01:43 PM
biketrax's Avatar
Found a site that had Exploded view of parts. I ordered the water pump,15 bucks which did most of the pumping on the spin/drain cycle. It solved the Leak and for now the spin cycle works better! which is very understandable. Hope this helps someone!
