Dishwasher Drains Slowly
Old 04-17-21, 06:31 AM
W
Considering buying a used dishwasher that drains slowly.
What might be the cause of slow draining? Filter needs cleaning? Plugged hose?
Thanks for any help you can give.
Wayne
Old 04-17-21, 06:45 AM
Norm201's Avatar
Received 356 Votes on 321 Posts
Yes and yes. Could be a number of things. Can you inspect the unit prior to purchasing? If you know it's malfunctioning why would consider buying it? Unless you like working and repair used equipment.
Old 04-17-21, 07:04 AM
W
Cuz it's cheap. Cuz it's cheap.
Old 04-17-21, 07:09 AM
Norm201's Avatar
I see where you're coming from.
In my youth I use to garbage pick and try to rebuild things. Especially old vacuum cleaners. I see my son doing that now and I kind of laugh at him but also admire him at the same time.
Old 04-17-21, 08:15 AM
Received 1,509 Votes on 1,396 Posts
Plus drain pump issues, clogged sump.
Shouldn't be too hard to figure out.
Old 04-17-21, 11:29 AM
Received 164 Votes on 151 Posts
Get the model number and look it up.
With a little luck you may find a service manual.
But should at least be able to find a parts breakdown so you know how it is put together and what some of the most likely parts cost
