Oven was taking forever to heat up. Check voltage to elements and was only getting 120v on one plug off element other was zero. Pulled circuit board and completing blown where the solenoid is. Is there something else to check in wiring or could it be from the board itself shorting? Don’t want to put new board in and have it blow. Thanks
Reason: cropped/reoriented pics
A pretty common failure. You may actually be able to fix that board if you had solder and some minor parts.
I would use an ohmmeter and check from the end of each element to ground for shorts.
More than likely there won't be but I always check.
Usually what happens is there is a bad solder connection that starts to arc from the high current drawn thru it. As it arcs it melts/eats more of the pc board foil until finally the arc stops from the large gap.
It looks to me like L1 blew out,
By the way it blew the track off the board I would say that you have a dead short somewhere in the unit.
Does not necessarily have to be an element if I am correct.
First look for scorch marks in the unit.
If all clear then check elements etc, for a short to ground.
Those three boxes are 30 amp relays with 12v[dc] coils. You could check that the relay coils are getting their voltage.
The total element wattage should then be less than 7200w & the total element resistance should be more than 8 ohms.
There is the control board, the elements & the connections between them.
The board could fail for a reason within itself or it can be overstressed by a shorted element or short circuit elsewhere.
A bad connection passing heavy current could fail to an open circuit.
A schematic will help narrow down the one or more possibilities.
So, in full, there is the control board, the relay coils, the relay contacts, the connections, the wiring & the elements.
Here’s a wiring diagram. Does look like some one shorted the l2 plug off the bake element to the oven plate. The convection plugs have got hot before as you can see in the one picture. Don’t know what that’s means but they were a bit loose so I tightened them up. Could that short from l2 be what blow the board? L2 bake element Convection element plugs
Last pic shows overheated connectors due to connectors losing their spring temper. Need new [molex?] connectors.
Next to last pic shows arcing due to short circuit which might have ruined the contacts inside your relays.
How much time & mat'l have you spent so far & how much for a new unit?
Yes..... the element touching ground blew the foil off the board.
The board may still be ok.
You can fix the burned foil.
You won't know if the board is still working until you fix that burned foil and fire it up.
Only spent 150$ so far on the two fan motors and about 2 hrs figuring stuff out. It was a free stove and similar one is around 2000$. It’s about 6 or so years old I believe. New circuit board is about 150$ Don’t know if I’d trust myself fixing the blown section or not can maybe play with it and see or just pick up a new one. I’ll put some new ends on the connectors that got hot. Thanks for your help guys.
Of course it didnt make this noise during the inspection but now that we actually want to use it, the dryer ran quietly for about 5 minutes and then started this very high pitched noise. It's a GE, not entirely sure of the model. It still produces heat. Any chance this is an easy fix?
Thanks
Video: [url]https://streamable.com/r0libe[/url]Read More
Could someone please tell me how I can remove the front panel of this dryer so I can clean out the lint that has accumulated underneath and at the back of the drum? Thank you.
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/623x742/cc39bd34_5f50_4ed7_a431_dac0b1d4a832_b6e2014ac869707085003c109369c3eb6198e5da.jpeg[/img]
[i]PCKS443EBWW[/i]Read More
