Maytag la212 washer leaks on the spin cycle
Old 12-14-21, 06:10 PM
B
It isn't wet on the tub bottom where the seal is, the hose on the back isn't wet, and no leak around the pump. The inside of the back panel gets some spray, and there is a puddle of water on the floor.
Thanks
Old 12-15-21, 01:14 PM
Received 3,596 Upvotes on 3,225 Posts
Where's the puddle..... towards the back ?
Possible hole in the drain hose.
Old 12-16-21, 09:19 AM
B
It collects on the inside left panel and goes out there. It looked like it was coming from the upper hose. A hole makes sense.
Old 12-16-21, 02:10 PM
B
The plastic ventilated part is leaking. One parts diagram didn't have it.
Old 12-16-21, 03:19 PM
B
Looks like an injector sleeve
Old 12-17-21, 03:24 AM
Received 280 Upvotes on 251 Posts
Old 12-19-21, 07:25 AM
B
I was going to order the sleeve, but your advice on the kit is a better idea. This machine is worth fixing. Thank you.
Old 01-01-22, 11:45 AM
B
I by passes the plastic piece, but water still rolls on the top of the tub. Epoxy should fill the rust holes
