My whirlpool dryer stopped working when I went to put it back on after checking the clothes. When I pushed the on switch it didn’t go back on. Also tried the selection knob on the left and nothing. The light was on in the dryer so it was getting power. I left it overnight. This morning I tried it and when I pushed the on switch,it tried to go on for a second but it would not go on. I tried it twice and it wanted to but it would not stay on. Bad power switch?
model LEB6300OW1 whirlpool.
I cannot find any info using the given model number.
Also what does "it tried to go on for a second " mean.
Do you have the tech sheet? Often it is stored in the console.
When I went to push the power switch it powered up for a split second like it was go to stay on but it stopped. I did this twice but now it does nothing again.
If the motor has a start capacitor I would check that. Also see if the motor turns freely. It's bearings/bushings may have seized or worn out. Also check for any mechanical binding or scraping of the drum.
LEB6300OW1 ...... needs to be corrected. Looks like it should be LEB6300PW1 or LEB6300LW1.
I used LEB6300PW1 which uses a 3979703 tech sheet.
That uses a combination button and relay. (WP3398095) It may not be bad. It may not be getting the power it needs on the hold side from the blue wire. That could possibly mean the non resettable thermal fuse may have blown open.
The upper arm of my Bosch DW is not spinning. I called Bosch and they gave me tips on cleaning/flushing. I flushed it - still does not spin. I thought the water level was low and added water into the unit. After adding 64 oz I was able to get water to come out of the holes in the upper arm but, it will not spin. The lower arm spins.
I have tried different options on the panel but, no change to DW operation. Any idea what is causing the problem with water level and arm spinning? Could it be a pump that is not forcing enough water?
Thank you
Read More
I have a Viking stove with electric oven model vdsc365-6bss. I would like to replace the oven door latch for the self cleaning. Could any one help. Thanks AlRead More
