Hello, thank you in advance to anyone that can help. Today we replace the drain pump assembly on our GE top load washing machine, being very careful and following ALL instructions properly. After the repair and running it through a small load cycle to test it out, I noticed that the drum has dropped a couple or so inches. It is running properly, agitator is fine, draining properly with NO noises or banging. What could of happened and what is needed to be done? Please help I can't afford a new one and this is only 4 years old, I have had it about 2 years old and was purchased new. Thank you and have a good day.
413 is a ball joint and 414 is a rod and spring assembly.
There are at least three and probably four.
One or more may become disconnected..... probably at the bottom.
When I work with hay, I get little pieces all stuck to my socks, etc..Can I just throw these clothes into the washing machine? Or will I overload it w/ debris and cause a problem in the drainage system or something?Read More
For ASKO dryer model 7005 I need high and low temp cycling thermostats. OEM numbers were 8001543 and 8001444. They appear to be no longer available. Each was rated at 15A and had 3 contacts which flipped at 140 and 175 degrees respectively. Is there a replacement available? Could I put in two 4 prong universals and wire 3 poles separately?Read More
