front-loading washer no spin
Old 05-15-22, 09:47 AM
G
This is a front-loading Frigidaire Model GLTF2940ES3
The clothes were wet at the end of a wash cycle. I dialed it to drain/spin then pressed Start and it drained until est time 9 then tumbled slowly a couple of times until est time 7 then just shut off and beeped 3x. I thought it was doing this consistently, but one time when dialed to drain/spin, it added water, so I canceled then turned the dial around a couple of times, left it at drain/spin and pushed Start and again it drained until est time 9 then tumbled slowly a couple of times until est time 7 then just shut off and beeped 3x. I opened the top and the belt is in place; I watched it as it did the tumble.
Error code E47 was generated. Should I rely on this and just try to order the part?
Old 05-15-22, 11:00 AM
Received 3,611 Upvotes on 3,237 Posts
E47 is a problem with the door catch/switch.
All plastic and a typical problem area.
OEM part number 131763200 subbed to 131763256.
131763256 door catch
You can run it thru diagnostics. The tech sheet is inside the unit near the control panel.
You can also get it via a pdf....... here.
GaryMN voted this post useful.
Old 05-24-22, 01:28 PM
G
I got the part and put it in, and so far, so good.
Thanks!
