I have an AirVac Gold series, model #ZX6000, that has decided just to pulse rather than run when any remote outlets are used. The pulsing is on / off at about 2-second intervals. It works just fine with the tank switch. The pulsing occurs at all of the remote outlets. Any solutions or suggestions on where to start analyzing?
The switches are all open circuit and all connected in parallel.
There should be two terminals right on the unit.... try shorting them with a screwdriver.
Does it run ok there ?
When I short across the two control wires at the tank, the unit does not come on. I am not certain I am making good contact though as when I remove the control wires and jumper across the two tank terminals the unit comes on and runs fine. If I install the two control wires to the tank and go to a remote outlet and jumper across the two terminals there, the unit pulses.
Ok... good. So that's telling you that the vacuum itself is ok and the problem is strictly external.
With that being said you have a confusing problem. Most central vac hose connection ports create a short when the hose in inserted. You've tried a short and get the system pulsing. On the surface that says the wiring is too small/thin. That would be very rare as the unit has an internal transformer and the remote is forming a basic low voltage switch. The amount of current should be minimal.
That's a standard AirVac open circuit connection. As I explained before.... a short anywhere on those two wires should make the vacuum run and stay running. The specs call for #18 wiring. I've seen smaller used and work.
Do you have the wall connection plates with the 120v for powered tools ?
The wall plate is held in with two screws. It can be removed without harming the vacuum pipe in the wall. The plate was designed to be changed. I would pull it out and try shorting the low voltage wires there.
The wires appear to be 18 guage and the outside sheathing says "Type CL2". There are 3 conductors, white, red, and black. The red goes to the green indicator light that flashes when it is time to change the filter. It is getting power as it is a constant green.
I have opened the wall plate and jumpered across the two conductors at the screws and that is when the system pulses. I opened another wall plate and it reacted the same way when I jumped across the same screws.
You mentioned a transformer inside the unit. Could it have developed a problem? The unit is about 23 years old.
The CL2 makes is type accepted for in wall low voltage wiring.
I'm at a loss. I've never seen a system with the filter light on the plate and I've worked on many.
I can't find a control board that supports the filter light.
There are basically two boards. One has the transformer on it and the other has a separate transformer.
Can you shoot and post a few pics of the system for me. The top of the motor should come off and you can see into the unit there.... How to insert pictures.
The way my system is mounted, the motor cover is on the bottom. Here are a few pictures of its workings. It does look to be rather simple, but I guess the real system is on the little board. It does have the transformer on it. I included a picture of the outside of the tank where the control wires plug in. The button is a fuse and the little light is the one that is on solid green all the time, but it begins to flash green to indicate the filter needs changing. This same green light is on all the wall outlets and will flash green there at the same time.
Incidentally, I decided to check the voltage across the two screws on the wall outlets. When I touch a voltmeter to them, the unit came on and still pulsed. But the interesting thing is that when I removed the voltmeter leads, the unit continued to run. I had to unplug it to turn it off.
That is a M-CB15A control board. Very basic. No logic. Transformer and relay. A typical two wire system that's found in most central vacs.
We need to clear up some previous discussed issues.
You said there was a three wire connection from the vacuum to the plates. I don't see a three wire connection at the vac. I see a red and white wire connected. At the plates you have three wires ?
You said the red wire goes to the LED. That would not be correct. A direct short is required on red and white. The LED in the red line would be a problem.
I have a feeling that you have plates there that do not not belong to that system. You need the red and white wires to be on the switched contacts. So far.... I haven't seen anything that would require the third/black wire.
You are correct in that there is only a red and white conductor. However, the red is connected to the green light that I mentioned and there is a black jumper from there back to the other side of the switch. The green light is only on if the hose is in place and shorts across the two wires. The green light is on continuously at the tank. Here is a picture of a wall outlet. I opened another wall plate and it is wired the same way.
Disconnect the LED.
Connect the red wire to where the black wire is currently connected.
The vac won't fire up with the LED in series.
I've never seen that type of plate and I'm not sure how the LED is electrically supposed to work.
I haven't been able locate that type of plate in any of my supply company catalogs.
Will I need to do the disconnect at all wall plates, or can I do it at only one as a test? The system has been in place for over 20 years and worked until a week or so ago.
I've never worked on a vac system that had the LED in the plate. I'm trying to find more info. If you see a model number on the plate.... post it. Maybe post a picture of the LED area.
With most vacs the transformer and the control relay are both AC. The LED inline would send DC to the relay. That would keep the relay from getting a true 24vac. The Electrolux system uses DC switching and those plates would work there.
I rewired one wall outlet to take out the filter status light. When I jumpered the outlet, the vacuum came on and ran fine. When I removed the jumper, it stopped. I then rewired the other 3 wall outlets downstairs and decided to test the system with the vacuum hose and carpet head. It worked just fine. When I turned the switch on the head off, the system turned off. But when I removed the hose from the wall outlet the system turned back on and began pulsing. Maybe I have to complete the rewiring of all wall outlets for the system to work.
Here are some pictures of the wall outlet plates. The brand appears to be Electravalve.
Thank you so much for your patience and help. I know it took me a long time, but I finally finished rewiring all of the wall outlets to remove the led bulbs and wiring. Low and behold, the system seems to work normally.
We just got a new LG washtower as we're trying to save space in our laundry room (and add a utility sink).
Using the existing vent to outside (and lengthy/sturdy hose) , the closest the installers could get to the wall (to the left of unit when facing it) is about 10" or so.
We'd like to cut that distance in half by either having someone cut a new hole for the exhaust vent right up next to the vent coming off the dryer (so that we can literally just run the hose a few inches straight out from unit into wall), or would it be easier/better to get something like [url]https://smile.amazon.com/dp/B01FF4ASTS[/url] or [url]https://smile.amazon.com/gp/product/B08V47X3YF[/url] or even as simple as [url]https://smile.amazon.com/gp/product/B08XXW1N1P[/url] (I would put one directly on dryer and one on vent). Or maybe there's 'softer'/more flexible ducting that could bend more and save us space?
Thanks for any thoughts/suggestions.
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/645x853/3_70f345eb05236294bdcabfbc587a48bdb3310993.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/657x858/2_2_bda6cb895eda1a7c60d9446f2715b2691c3a2cd6.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/644x859/1_2_240099ede0bb04559226774ce28db5ba90fde06a.jpg[/img]
Read More
Hello. I asked a question about repairing my fridge in a different forum but the information I got about how to use a multimeter is not sufficient for a newbie to try. So I need your help.
I want to test the defroster heater on my fridge with a multimeter so that I can see if it's working. Please see highlighted part of attached image, with shows its "jacks."
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/pic_of_coils_highlighted_li_eef38a37d836868e872a85c806118d26772ed506.jpg[/img]
I cannot remove the defrost heater because, if you'll look carefully, the bottommost L-shaped coil on our left is blocking the screw that holds it to the evaporator (ridiculous design flaw). So I would have to hold with prongs of the meter in those holes with my hands. The fridge is UNPLUGGED and the water valve is CLOSED, so I'm assuming this would not pose an electrocution hazard (please confirm!).
So, I need to know: (1) What meter to buy; and (2) how to use it. By how to use it, not only do I mean in general; I need to know the specific settings for the meter and what values I should hope to see. Here's a link to the fridge's manual:
[url]https://dokumen.tips/documents/31-9072-arctica-profile-ge-side-by-side-refrigerator-service-manual.html?page=1[/url]
Here's what another user said, which is a little over my head:
[QUOTE]You put the leads where you said earlier. Use the lowest setting that is higher that what you expect to read. So for 27 ohms the 200 ohm scale is normally used. Then if it read infinite ohms (open) you can try higher scales.[/QUOTE]
Thank you!
Read More
