Options for exhaust venting from dryer
Old 05-31-22, 04:54 AM
N
Received 1 Upvote on 1 Post
We just got a new LG washtower as we're trying to save space in our laundry room (and add a utility sink).
Using the existing vent to outside (and lengthy/sturdy hose) , the closest the installers could get to the wall (to the left of unit when facing it) is about 10" or so.
We'd like to cut that distance in half by either having someone cut a new hole for the exhaust vent right up next to the vent coming off the dryer (so that we can literally just run the hose a few inches straight out from unit into wall), or would it be easier/better to get something like https://smile.amazon.com/dp/B01FF4ASTS or https://smile.amazon.com/gp/product/B08V47X3YF or even as simple as https://smile.amazon.com/gp/product/B08XXW1N1P (I would put one directly on dryer and one on vent). Or maybe there's 'softer'/more flexible ducting that could bend more and save us space?
Thanks for any thoughts/suggestions.
Old 05-31-22, 05:56 AM
T
Received 96 Upvotes on 85 Posts
In terms of moving the vent hole, I think it depends on what's on the other side of the wall. On the elbows, I believe either of your options would work but I prefer metal elbows for a little extra high temp protection, particularly for the elbow at the dryer.
Old 05-31-22, 05:57 AM
XSleeper's Avatar
Received 1,810 Upvotes on 1,628 Posts
Old 05-31-22, 06:03 AM
N
Thanks. other side of wall is perfectly clear so that's no issue.
that periscope vent looks interesting. i'll definitely see if that's an option for my scenario, which it looks like it would be.
Old 05-31-22, 06:29 AM
T
Periscope vents are available over 5" so you shouldn't have a problem finding one to fit your needs. If you go that route, make certain the one you select can be taken apart for cleaning.
Old 05-31-22, 06:34 AM
H
Received 279 Upvotes on 239 Posts
Well, I use an oval metal 'hammer head" vent tube adapter to get the dryer to sit back a bit further, also acts like a secondary 'lint trap' for light items that go through the dryer but don't stick to the lint screen - e.g. - buttons, money, small bits of paper etc.
Old 05-31-22, 11:02 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Had one of those periscope vents once, they leak like crazy, utility room was always a mess just could not get them sealed. These off set elbows work much better.
https://www.amazon.com/Dryer-Venting...a-584138346909
Old 05-31-22, 11:32 AM
H
I've found over the years, that metallic duct tape can fix almost any fluid leak -air, water...
HOWEVER, you gotta, gotta, wear leather work gloves to avoid "a death of 100 paper cuts"...
Old 05-31-22, 12:29 PM
N
Thanks. I'll look into this option as well. https://www.amazon.com/Dryer-Venting.../dp/B000DZDPI6
Old 05-31-22, 12:46 PM
N
Would you set it up like this? Essentially, using existing hose (or a shorter replacement one), instead of hose going into unit at top, the adapter goes into unit (essentially becoming an extension of the unit's built in connector), and then hose connects from bottom of adapter and into existing vent in wall.
This seems like a good, simple option, with no real points for clogging/leaking/etc... assuming everything is tightened properly.
Old 05-31-22, 12:57 PM
2
Received 356 Upvotes on 308 Posts
Use 2. One at the top and one at the bottom. Basically a flexible periscope connection.
Old 05-31-22, 12:58 PM
N
Thanks. Not sure I need it that close as I want to leave a little room away from the heater. But I'll see what works best.
Thanks again.
Old 05-31-22, 02:08 PM
Marq1's Avatar
Both of those are for minimizing distance between appliance and wall, with that heater you could problaby just use regular 90's with a piece of hard duct, don't use flex pipes on dryers, they collect lint!
XSleeper voted this post useful.
