Maytag washer burning smell
Old 06-07-22, 03:08 PM
F
Wife told me the washer had a burned smell, had her cut it off and it was full of water. I assumed pump had went bad so i pulled the pump out when i got home but I can spin it fine in my hand. So not sure if that is the issue or not. Model HAV4657aww. It has the original belt on it as well.
Old 06-07-22, 03:19 PM
Received 3,634 Upvotes on 3,256 Posts
Typically when you smell burning.... it's the belt slipping.
Old 06-08-22, 11:59 AM
F
I can turn the motor and the drum with my hand. The belt also seems fine. I ordered a replacement pump but i can also turn the old one with it out of the machine. I am guessing the smell is as you say from the belt slipping, just unsure why it was.
Old 06-13-22, 05:51 PM
F
so thought it was water pump, replaced that and filled up washer and when it started to agitate it started making a squeaky noise and then it sounded like a grinding noise. guess transmission or a bearing is going bad. not sure if thats worth the hastle to fix.
