LG Range Cooktop element won't turn off
Old 06-27-22, 07:23 PM
G
We have LG - model LRE3083ST/00 where the front right glass top cooktop element will not turn off after turning it off on the push button keypad. The display shows "HS" but the element is staying on. Any help would be appreciated. The range is almost 10 years old. (eventually after 10 minutes or so the element finally turned off). Worried that it will come back on its own when were not home or whatever. Any suggestions to consider before calling for repair service... i.e like replace a part. Thanks.
Old 07-09-22, 04:39 PM
G
Update. Now when the back right burner was turned on the front right burner also turned on.
Old 07-09-22, 05:05 PM
Received 4,155 Upvotes on 3,731 Posts
Unfortunately this does not look like a DIY repair.
This is a very involved electric range. Very expensive control board.
There may be a tech sheet in a plastic bag on the back of the range.
It may have some helpful information on it.
I was looking at the service manual for a similar unit.... very technical.
Similar downloadable service manual
Old 07-10-22, 02:47 AM
B
Received 322 Upvotes on 284 Posts
Could the light you see be a Hot Surface indication and not the status of the burner you shut off. The HS light is controlled by a temperature sensitive switch and will stay light after the last burner is off until the temperature off setpoint is reached.
Old 07-11-22, 11:47 AM
G
Thanks for the feedback. Yes, I noticed the control board is expensive, about 1/3 the cost of a new Range.
Old 07-11-22, 12:37 PM
It could be an indicator issue but that wouldn't explain one burner apparently turning on when another one is turned on.
