Loose condenser fan blade
How can I tighten the fan blade on a Habco 42 cooler?
it has a screw on the end but not sure how to keep the shaft from turning while I tighten the screw.
Welcome to the forums.
I'm guessing that is a threaded shaft motor with a nut that holds the blades on.
Is that correct ?
If the shaft is spinning you may have to use a small pair of channel lock pliers or maybe needle nose pliers to gently hold the shaft from turning.
Is that correct ?
