You need to check for 120vAC at the two wires that go to the wash pump when it should be running. If there is no power it could be a blown fuse inside the control box. The tech sheet will help you.
Below is a pdf download link for W10751166 rev.C tech sheet.
Let me know when you have it as I don't usually leave them posted.
OEM # W11032770 wash pump motor assy.
The pump needs a special pair of crimping pliers to crimp the hose clamp.
Shown in the amazon link...... Pump on amazon
Reason: Removed tech sheet. Will supply on request.
I got the document. Thank you. I'll review it and check.
I saw elsewhere to check for blockages in the motor. I'm not sure how to do that, but that might not apply here. If the motor were blocked, wouldn't I still hear it trying to work? I hear nothing at all besides a soft click when I would expect the spinning washers to start up.
That is a high torque motor with a short duty rating posted on it. That means it will overheat quickly.
It is possibly to be bound and can't spin.
You may be able to lower the pump from the sump to check for a blockage and at that time you should see the impeller and try to turn it manually.
So, some more information... I removed the sump assembly. I took the circulation pump off and spun the impeller manually for a while. I inspected for blockages and found nothing. It was very clean, but I ran water through it to make sure. I was careful not to get water on the electrical contacts. I then put it all back together and started an empty normal cycle. During the wash cycle, it made a pretty loud grinding sound (more or less... if I didn't know what the washer normally sounded like you might be able to convince me it was just a really loud washer). This happened a couple of times. After that, it returned to how it was before I took it apart-- it filled with water, but the washing stages didn't work. I then did a 1 hour wash cycle and timed the cycles by this chart from the technician's manual:
When it got to the first heated wash stage it became completely quiet, no activity at all, for 3 minutes, and then drained. It seems like spinning the impeller allowed it to work for a short time, but then it failed again. Is there any way it could be anything but the circulator motor? I'd like to test the power input, but it seems like the loud, grinding sound indicates that it has power.
It certainly sounds like there is something hitting the impeller.
The motor is probably thermally protected and is going into overload/thermal shutdown.
Can you get to the plug and connect your meter ?
You really need to know what the power is doing.
4 yr old bosch needs 500 dollar control board. due to very particular space requirements i'm limited on what ovens i can buy. (23.5 wide max)
turns out miele will fit. insanely expensive but i'm almost considering it. unsure the low oven or full size. im not a master chef. but getting the smaller means i have 5 inches of height to cover up then.
other option i found is samsung. i'm sure there are more . but not much more.Read More
sometimes. I have a Kitchenaid DW model KDPM604KPS). It was 2 years old in June. A couple of weeks ago we started intermittently getting error code E1F9 and the wash cycle would stop, I could cancel the cycle and hit the drain button and the DW would drain.
I disconnected the drain line from the house plumbing and ran a wash cycle into a bucket. It drained correctly. Thinking I had a plumbing problem I disassembled all of the under sink stuff looking for a clog. It was fine. I tried another wash cycle with the drain line feeding a buck and got the error code again.
I would like to inspect/clean the drain filter but I can't find it. I don't think that would be the problem since the one tiime it drained correctly there was a lot of flow. All the stuff I find on line show a cartridge type filter under the spray arm. My configuration is different. I can find no drain filter just a grate screen in the bottom of the tub.
Any ideas where to look next? Unfortunately I'm thinking control board or drain pump.Read More
