Dishwasher won't drain . . . .
Old 07-18-22, 12:00 PM
C
Received 307 Upvotes on 254 Posts
Arrow Dishwasher won't drain . . . .
sometimes. I have a Kitchenaid DW model KDPM604KPS). It was 2 years old in June. A couple of weeks ago we started intermittently getting error code E1F9 and the wash cycle would stop, I could cancel the cycle and hit the drain button and the DW would drain.
I disconnected the drain line from the house plumbing and ran a wash cycle into a bucket. It drained correctly. Thinking I had a plumbing problem I disassembled all of the under sink stuff looking for a clog. It was fine. I tried another wash cycle with the drain line feeding a buck and got the error code again.
I would like to inspect/clean the drain filter but I can't find it. I don't think that would be the problem since the one tiime it drained correctly there was a lot of flow. All the stuff I find on line show a cartridge type filter under the spray arm. My configuration is different. I can find no drain filter just a grate screen in the bottom of the tub.
Any ideas where to look next? Unfortunately I'm thinking control board or drain pump.
Old 07-18-22, 12:54 PM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
I suspect that after checking everything you did, I also agree it may be faulty control board. I doubt the pump is bad. It either works or it doesn't.
No brand has any reliability behind anymore.
Old 07-18-22, 07:58 PM
Received 3,607 Upvotes on 3,234 Posts
Could be something in the pump.
Sometimes it takes pulling the pump and visually checking it.
Not the easiest unit to work on.
Tech sheet/manual - W11447459 ........ Whirlpool tech manual - pdf
(Let me know when you have it as I don't leave tech sheets posted.)
I need the complete model number to check on the sump/filter issue.
Drain pump removal video
Is the drain line attached to the underside of the countertop ?
Old 07-19-22, 08:07 AM
C
Unhappy
The DW is a Kitchenaid KDPM604KPS0. I think the drain pump is working OK because it drains when I select "drain" on the control panel. It's pretty quiet bu I can hear the pump running when I select drain. Currently it gets part way through the wash cycle and then stops and I have to drain it from the control panel.
I think I'm going to have to bite the bullet and make a service call.Unhappy
