Need the service manual for Whirlpool French Door Refrigerator WRF535SWHZ
Old 08-08-22, 08:44 AM
Q
Received 1 Upvote on 1 Post
Arrow Need the service manual for Whirlpool French Door Refrigerator WRF535SWHZ
Hello all,
Can someone please share the service manual of the Whirlpool French Door Refrigerator WRF535SWHZ with me?
Thank you
Old 08-08-22, 09:30 AM
willywhy's Avatar
Received 1 Upvote on 2 Posts
Old 08-08-22, 09:59 AM
Received 3,613 Upvotes on 3,239 Posts
It's better to post a full model number. You left finish and feature codes off the end.
I'm using.... WRF535SWHZ00
Service manuals are not usually free.
You can buy them from $9.95 - $19.95 on a digital download.
I have many tech sheets for appliances. Your fridge has one included within it. It'll be folded in a little plastic bag. It can be found under the front kickplate or by the compressor. Tech sheets have basic diagnostic information on them and are usually quite helpful.
You can use the PUB W10517966. I left a pdf copy below.
What is the problem you need help with ?
File Type: pdf
q0987 voted this post useful.
Old 08-08-22, 10:33 AM
Q
Hello PJmax,
I want to know
1> How to clean the condenser coil.
2> How to disable the ice maker completely(i.e. disconnect the power coil)
Thank you
Old 08-08-22, 11:02 AM
Pull the fridge away from the wall. Unplug.
Remove cardboard "cover" if present....carefully. They get brittle with age.
You'll see the condenser coils and the fan. Vacuum as much dust as you can from the coils and fan. Try not to bend the fins on the condenser. Sometimes an extension wand makes the job easier.
The icemaker will have a short lead and plug on it. Just squeeze the two ends and unplug it.
