Last week, I replaced a broken seal of the circulation pump, to be specific this one.
I also replaced the following seals circled in red:
I have re-assembled everything, and the dishwasher has worked perfectly for three days.
On day four, it started to be very noisy during the washing cycle, no errors, and the dishes are clean.
I have recorded a video last night, the program was 'EnergySave' and it started with 2'40" remaining time.
After 1'15", there was the first water drainage, which is the beginning of my video.
In the video, at minute 1'25" you will hear a strange noise during the water intake.
Once the water intake has been completed, the washing is resumed, but it is very noisy.
That noise you hear during the water intake, it only happens once during the entire washing cycle, and it does it in any program I choose.
Since the whole thing started after only 3 days I replaced the circulation pump seal, I am thinking and re-thinking if I re-assembled something wrong, but really, there is not much margin of error here, because all the seals I have replaced have only one position, so really I do not know what to think.
I hope some of you recognizes where possibly that noise can come from.
Not a machine I'm familiar with but that is the sound of the wash pump turning on with no water. It sounds like the pump is binding from a dry seal or almost sounds like a problem with the macerater or grinder disc. It sounds almost normal when it restart at 2:00.
It sounds just like a saw that is binding in damp/wet wood.
I watched the rebuilding video. A fairly complicated pump.
It would have been a little more helpful to me in English but fascinating anyway.
I could envision that motor seal assembly making that noise.
My pump is a bit simpler than the one shown in the video, but the seal is identical.
The technician in the video, added some silicone oil when re-assembling, I did not.
I do not think that is the root cause of the problem, the silicone is just to protect the seal rubber as it is supposed to last longer with that silicone.
There is enough water intake, nothing has changed, in fact, any washing cycle works fine, no errors, no leaks.
I can only disassemble the pump/engine again, but honestly, I do not expect to find anything wrong, it is hard when you have no error codes or mechanical idea where the noise comes from.
I will try to identify where exactly the noise generates, but yes, it sounds to be the pump.
If you look at the images below, after 16 years everything looks new. What a machine is that!
BTW, I do not speak German either, but the video was very helpful!
I opened the pump, and I found the cause of the problem.
The cap below needs to be on top of the other plastic cap, and I need to fix it using some glue, but I am not sure which one to use.
I am thinking of two possibilities:
Epoxy
Loctite
But I am not sure if they will resist long-term to temperature, detergent and water.
For instance, what do you think of this one:
Any advice is very welcome!
Thank you,
Alex
NB: Maybe you can see the images more clear here:
Hello everyone. I have a Maytag washing machine, model MVWB765FW2 , it's a top load HE machine with an agitator and a glass door. I recently had to move
the machine only to find a grease splatter on the floor where it sat. Sure enough it was all around the bottom inside of the machine as well. I read that this meant the gearcase was bad. On this model you have to purchase the entire case, individual seals and bearings are not available. Anyway after getting the old gearcase out, it did not appear to be all that bad, seals and bearings looked to be in good shape. The wife said the machine wasn't any louder or acting any differently. When I flipped the old case over (during inspection) a tiny, maybe nickel sized amount of brown rusty water came out of the top. So i am guessing the "grease" was actually rusty water. But other than that everything was fine. It came apart easy too. I am not an appliance expert [b]and was just wondering what you guys thought, cause it didnt seem to show any signs (that i know of) of a bad gearcase or failing seal or bearing. [/b]
It usually works if not loaded to heavy. Even after taking clothes out it pops and smells like the motor is burning. Tried unplugging for a few minutes and trying a different circuit which didn't help. Sometimes if left sitting awhile it will start up again.
The wash cycle works ok.
Thanks
