Dishwasher buzzing
Old 03-20-23, 06:50 AM
N
Received 1 Upvote on 1 Post
Dishwasher buzzing
Any thoughts on what this buzzing sound is coming from the very bottom of the dishwasher?
https://www.dropbox.com/s/mr1wuszmxj...0buzz.mp4?dl=0
It happened once and we haven't run it again yet (just want to make sure it doesn't sound too serious before we do so).
Thank you!
Old 03-20-23, 10:57 AM
2
Received 336 Upvotes on 288 Posts
What make/model dishwasher? Some older models have a food grinder in the sump. A piece of broken glass or a food pit in a grinder can cause a noise like that. Check the sump below the filter.
Old 03-20-23, 11:09 AM
N
Thanks. It's a GE from around 2012 or 2013. I'll poke around to see if I can find anything stuck.
Old 03-20-23, 12:08 PM
Received 3,485 Upvotes on 3,128 Posts
I can hear that it's in washing mode as I can hear the water sloshing inside.
The spray arm is turning.
It's hard to tell what that noise is. It could almost be a bearing noise in the wash pump.
There can be items that fall down into the sump like bone, plastic, glass but they are usually louder than that.
A model number would be helpful.
Old 03-20-23, 02:23 PM
N
Thank you. Here is the model: GDWT668VSS
https://www.geappliances.com/applian...ols-GDWT668VSS
Old 03-21-23, 12:55 PM
That's the group model number.
Try to locate the ID tag and post the full model number.
Old 04-17-23, 08:10 AM
N
Sorry for the late reply, but I haven't been able to locate any ID tag with a full model #. In your best guesstimation, given that the unit is around 9-10 years old, is it worth trying to get it serviced (i.e. it might be a quick/cheap fix, though still probably looking at $150-$200 minimum just to get someone out here), or just get a new machine at this point?
