Kenmore Refrigerator/Freezer not keeping cold anymore
Old 03-26-24, 06:48 AM
A
I rolled the fridge forward from the wall and cleaned the evaporator coils at the back and this did not help.
Next I removed the inside back freezer panel and was surprised that the the evaporator fins/coils were not frozen except for the steel line that comes down from the top part of the freezer. I warmed it up manually with a hair dryer and after about an hour the steel line was frosting/freezing again but the evaporator fins/coils were still warm.
Temperature is currently 50 degrees in both freezer and refrigerator. The freezer fan keeps running and when I did the cleanup of the coils at the back, the compressor was pretty warm/hot so I think it's ok. Also I did hear it shut down for about 30 minutes for a defrost cycle but it's back running now.
Wondering if anyone can help me out here. The Kenmore was purchased in 2008.
Thanks in advance.
Old 03-26-24, 09:12 AM
P
Received 2,190 Upvotes on 1,959 Posts
Post the model number so we know which fridge you are talking about.
Old 03-26-24, 09:15 AM
Received 296 Upvotes on 266 Posts
Since the compressor is running and the evaporator is not getting cold it is a sealed system problem.
Likely low freon.
Probably not worth fixing as you will need a pro.
CircuitBreaker voted this post useful.
Old 03-26-24, 11:29 AM
Received 3,999 Upvotes on 3,589 Posts
As mentioned.... your system has a refrigerant leak and is low.
Unless the fridge is under warranty.... it's time to replace it.
Old 03-26-24, 12:41 PM
A
The model number is 970-438741.
Old 03-31-24, 07:14 PM
That's a Frigidaire built fridge for Kenmore......probably under Electrolux Canada.
Old 04-01-24, 07:04 AM
A
Based on the comments above we purchased a new refrigerator. Since I first posted, the refrigerator lost all cooling capability. Growing up I was used to refrigerators lasting multiple decades and it’s a shame that these newer sealed systems are not worth fixing. This would be the forth breakdown of this refrigerator over the years. Anyway a big thank you to those of you who commented in this thread, much appreciated.
Old 04-01-24, 09:48 PM
It is unfortunate...... the sealed systems are no longer made to last.
Dehumidifiers have fared even worse.
