Vaccum cleaner
Vaccum cleaner
I have New Dirt devil ,upright, MVP 12 Amp,swival castor,Model No. 086310, Mfg code A98C,
I baught brand new in 1998, but all this years it was in werehouse, six montha go I started using.
Few months at ran very good, then I need to replace belt, now last two months after 30 minutes motor gets hot and it shuts down, there is no reset switch but I have to wait ( it says on vaccum cleaner ) 20 minutes and it starts again.
I open and clean the hoses, motor, brushes and re essemble.
Started again now it DOSEN'T vaccume as well as shuts down.!!!
Any idea how to fix this ? the brush roller is rotating clock wise ( is it right direction ? )
I will appreciate any help.
Thanks
Thanks
vaccum cleaner
Thanks
Thanks
Hello friends,
I will appreciate if some expert in this catogary take few minutes to look at my problem and help me and save my $ in unnecessary repir !!!
Thanks
Brainking,
Have you looked in the manual?
If you do not have one, download this one - click the latest download - 06/04
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=5301
From the sounds of it, it may need professional servicing. Being in a warehouse and not used should not had been a problem but yo0u don't mention how long it was used before being placed in storage. Being almost 8 years old, and if it was even used half that time, a professional service would be in order.
Hope this helps!
Hope this helps!
