my ise 17-56 just huming
my disposer just haming everything sims to be fine nothing is jamed
even the rest button did not help
thank you sol
thank you sol
Hi sol10, welcome to the DoItYourself.com forums
Are you talking about your garbage disposal and stating it is humming? If so, what have you done to make sure it's not jammed?
Received 7 Upvotes
If you are stating the garbage disposal motor is humming but the blades are not turning and nothing is jammed up, then it is possible the plastic or nylon break away bushing between the motor shaft and the cutting blades is broken.
You will have to remove the entire disposal, separate the the motor from the cutting head and replace the plastic or nylon bushing between the two assemblies.
The part will be available at a local appliance parts store in your area. Listed in a phone book. Bring the make, model and serial numbers with you and the broken part also.
