Above the range microwave without cabinet
Old 04-05-07, 02:37 PM
L
Question Above the range microwave without cabinet
Any ideas on how to attach an above the range microwave when there is no cabinet to attatch it to? I don't want to sit it on a shelf as there are lights on the bottom of the microwave that i hope to use. I do not have room or want to put up a cupboard just to attach the microwave. Any ideas?
Old 04-05-07, 03:03 PM
R
What is above the area where you want to install the microwave?
Old 04-05-07, 03:35 PM
T
Received 2 Upvotes on 2 Posts
Microwave vent hoods are intended to be mounted above the stove and attached to a cabinet. The vent unit and lighting is in the bottom of the unit.
Old 04-06-07, 07:22 PM
L
Question
there is nothing above the range where i want to mount it. I was thinking of perhaps just putting a shelf above it to mount th front of it to. I realize it will have to be strong but since there is a wall mount in the back would the shelf work? Thanks again!
Old 04-07-07, 05:12 AM
R
The shelf will carry a lot of the weight of the m/w and would have to be mounted as securely as a cabinet would be
Old 04-07-07, 09:34 AM
T
Shelf support would have to be sufficient to prevent shelf failure and sagging.
Old 04-23-07, 08:17 AM
D
We mounted ours without a cabinet, just followed the instructions for mounting to the wall, with the included wall bracket, and put a shelf above it, to mount the front top of the microwave to, and it holds and looks fine. We do have a wall cabinet on either side of this set up, but the microwave doesn't use the side cabinets for the actual mounting. Good luck!
