B & D Bread Maker Query...
Old 10-28-07, 11:18 AM
G
Unhappy B & D Bread Maker Query...
Hey ya'll,
A quick question from an electrical newbie. I've got a B & D Breadmaker (model B1650) that went dead all of a sudden like. After mucking around for a good long while and finally breaking a couple of small plastic tabs I got the sucker open and had a gander inside. The cause of the deadness appears to be an exploded small blue tab sticking up off the circuit board ( I assume this is a capacitor based on the bit of research I've done).
The Circuit board is labelled CB BD265 02 01
and the bit that blew up was in a location marked ZNR1
so the obvious questions are.
A) Can this little doodad be replaced easily enough (I can solder and whatnot assuming I kind find a replacement).
B) Where does one go if looking for a replacement for this kind of item?
Any and all comments would be appreciated.
GZ
Old 10-28-07, 06:12 PM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
What looks like a capacitor could be a fuseable link.
There is a good possibility that a high load downstream of the blown component caused it to go.
Unless you can find a schematic that shows the exact value and identity of the component it might be a waste of time.
I bought a near new bread maker at a yard sale last spring for $4.00 and this fall bought an updated model of the first one for $8.00.
I see these all the time at sales and I expect it would be less trouble to track down a good used one than to fix yours.
Old 10-28-07, 06:58 PM
G
Thanks Greg...I suspected that it might be pretty tricky getting the exact replacement part. It occurs to me that what would greatly simplify the matter would be finding a used/junked version of the same machine and simply swapping out the circuit board (provided it wasn't damaged).
I'll keep my eyes open.
