Bunn coffee maker
Old 04-20-13, 04:38 PM
jps
jps is offline
Bunn coffee maker
Have a Bunn coffee make, full of lime. Tried white vinegar, no luck. This is a later model. On the old models you could take apart and soak with vinegar, like new. Now they are sealed with some kind of caulk. Can,t get it apart. Tried heat, caulk would not release. Any ideas how to get the top off? TIA jps
Old 04-20-13, 04:41 PM
Received 517 Votes on 487 Posts
Historically Bunn made good machines.
Can you leave model number and I'll see if I can locate some info for you.
Old 04-20-13, 04:59 PM
jps
jps is offline
Model # GRX. Thanks for the reply!!! jps
Old 04-20-13, 06:58 PM
Received 2 Votes on 2 Posts
I have had sucess in the past with a product called dip it. Seems that it is not readily available in stores anymore but can still be found on the internet.
Also CLR will do the job - follow directions.
Old 04-22-13, 05:59 PM
Bunn GRX manual
In the above link is the owners manual.
I'm trying to find the parts break down to see if the boiler can be opened.
Old 04-28-13, 11:31 AM
jps
jps is offline
Bunn coffee make boiler
Hey TJ, our Bunn has a white adhesive gluing it together. Guess Bunn doesn't what us to take it apart. Try some heat on the adhesive, no luck. MAY TRY MORE HEAT. JPS
Old 04-28-13, 03:42 PM
Received 1 Vote on 1 Post
Just Curious
If you can't get the top off how do you know it's full of lime?
If mine seems slow I run that spring thingie through the tube and make sure the holes in the spray head are open and all is well.
My two cents worth.
Old 04-28-13, 10:04 PM
jps
jps is offline
Bunn and lime
Yes, I have used the little springy thing many times. I have used Bunn for around 20 years or more. Have had them apart about ever 2-3 years. When it starts to feel a little heavy. Most likly full of lime. Not unusual to get 2-4 cups of lime out. Depends on quality of water. Just hate to use softened water for coffee, not sure if that would be ok health wise. Guess there is no salt if softener is working as it should. jps
Old 04-29-13, 12:20 AM
Cups of lime ??
I never had that kind of problem with mine.
Maybe you need to clean it on a regular schedule.
Old 04-29-13, 10:10 PM
jps
jps is offline
Yes, you could be right PJ. Water quality effects alot!!! jps
