Electrolux Discovery III
Old 11-30-13, 05:53 PM
The carpet sweeper will not operate on our Electrolux Discovery III. The suction only option works. When the switch is moved down to the sweeper option (3rd) the motor cuts off. I have cleaned out the sweeper and tried resetting.
Old 11-30-13, 06:04 PM
Received 2,978 Votes on 2,686 Posts
Welcome to the forums.
Which motor cuts off ? The main suction motor ?
Old 11-30-13, 06:40 PM
The main motor cuts off when moving switch to sweeper option. Neither motor operates.
Old 11-30-13, 06:52 PM
Both motors do nop operate when sweeper is on.
Old 11-30-13, 09:01 PM
It would appear that the multi-postion power switch is defective. If yours uses the rocker type then the replacement is shown in the link below.
Electrolux 3 Position 3 Terminal Upright Rocker Switch
Old 12-01-13, 11:02 AM
Thank you for your help. I will let you know how it turns out.
Old 12-01-13, 11:06 AM
It isn't a rocker switch. Now what?
Old 12-01-13, 11:35 AM
Then it would use the alternate slide switch in the link below.
Electrolux 3 POSITION Upright Slide Switch
