Conair gs7 garment steamer
Old 08-27-14, 09:16 AM
The immersion heating element is not working. I tested the connections and electricity is flowing, thus I believe the heater is kaput. Where can I find a replacement part? I've been scouring the web, but without any luck. Thanks
Old 08-27-14, 11:39 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
You will need a model # gs7 is usually just the name.
Old 08-29-14, 02:29 PM
thanks for your reply. the bottom of the unit says model number GS7. When I called Conair they confirmed this was the model number. I have thoroughly de-calcified the elements. I have checked the terminals and they are hot. The terminals connect to a small white disc which is mounted on an aluminum (alloy?) The disc reads CH-150 -CL. I had to use a jewelers loop to see the letters. I haven"t been able to find any parts on the web. Thanks again.
Old 08-29-14, 04:40 PM
pugsl's Avatar
Could not find any parts either. Maybe somebody else will know.
Old 08-29-14, 06:22 PM
Received 2,977 Votes on 2,686 Posts
There is a GS-7RXF, GS-7R, GS-7TXR. It mostly breaks down to an upright unit or a floor model.
Possibly the GS7 Compact Upright Steamer ?
That silver disc is either a cycling thermostat or a safety thermostat. It either turns the element on and off to maintain a certain temperature or it opens if the unit runs to hot.
If you measure 120vac directly on the element..... that thermostat is good.
I don't know if a replacement heating element is available for that unit but based on the cost of a new machine.... I doubt it.
I've always had an issue trying to get Conair parts.
