Can I salvage this convection oven?
I bought a used version of this convection oven which the seller used easy-off on. I don't know what kind of easy off he used. The oven has a white powder all over and the metal or whatever was coating the inside and the "metal" has clearly corroded off. The heating elements are also covered by white powder.
Can this be salvaged by turning the oven on and putting it by a window or outside (during a cool, dry day), letting the residue evaporate until the fumes are gone? Or perhaps thouroughly washing it with a damp sponge? The problem is that the more you scrub it, the more of the "metal" comes off.
I really, really want to recover this thing because it costs $200 that I can't afford to spend.
Thanks
Thanks
Welcome to the forums! Posting an Amazon picture and an actual picture are night and day. We can't see yours, so we can't offer any suggestions. Post a few pictures, inside and out of your unit, so we can see what you see. I have a similar version in Oster, and cannot live with out it. I only store cast iron in my regular oven http://www.doityourself.com/forum/el...rt-images.html
You could clean it with a solution of vinegar and water to get the smell out. Clean and dry, then turn it on to get more of the fumes out.
The inside surface is probably shot. Oven cleaner isn't good for aluminum, stainless, or non-stick.
You might have all three inside oven
After a certain time limit, you can't edit the posts. Just part of the game. Posting an amendment to correct the first one is perfectly alright. Even us old timers goof and can't correct them until someone brings it to our attention.
You have a mess Too bad brain wasn't in gear before they decided to "clean" it. I would do as Brian suggested and make a solution of vinegar and wipe it down. Not sure if CLR or another type cleaner would work better, but it couldn't hurt it, IMO. Then a good "cooking" to clean it on the inside and you should be good to go May not be pretty, but functional, if it is anything like mine.
Also, are you sure it wont be a hazard, after doing what you and the others suggested?
Here's the one I have. Two large pizzas at one time. Love the double deck cooking. Uses convection as well, so, as I stated, I don't use my big oven, period. Oster Designed For Life 6-Slice Digital Toaster Oven - Walmart.com
I don't think, mechanically, anything is wrong with yours. If it is, it would be an expensive lesson Our Wal Mart had mine on a shelf with no price on it. I asked the lady to check on it for me. She came back with the box and instructions and said they had no listing for it, and would I give $40 for it. DUH. Pack that sucker up!
Most of the EasyOff products have a form of lye in them. That lye has eaten the finish of your oven. All you can do is to clean the chemical off as best you can.
Cleaning will not cause your unit to be a hazard. It's a cosmetic only thing.
Did you know before you bought this oven what the finish was like ?
If not it should be returnable on those grounds.
