GE microwave - bad door switch
Hello, .....................GE PEB2060DM2BB
When I start the microwave, the timer countdown starts, I hear few clicks but the turn table does not rotate and microwave does not start (no humming, no fan and no heat).
I suspect primary interlock switch must be bad.
Problem is - I can't seem to pull the connectors off from the primary interlock switch in order to replace/test it. Any idea that would do the trick?
That microwave should use two switches. One will have two terminals and the other has three terminals. The wires should just slide on.
Interlock switch - WB24X10047
Door switch - WB24X817
Thanks Pete,
Appreciate quick response.
I found those parts and already purchased them. My problem is that I can't remove connectors from the existing switch terminals. I tried to wiggle and pull, but something seems to be stuck or preventing from removing the connectors from the switch terminals...
Somewhere I read that sometimes those connectors will have a small plate (tongue) that kind of snaps in the hole on the switch terminals which makes it hard to pull.
Any idea?
Any idea?
Could possibly use a locking pin.....
You'd have to use a small pick to push the clip back out.
I use a screwdriver between body of part and clip. turn driver or pry it off. Will feel it pop out of clip.
Eureka!!
Yes, that was it. Pressing that while pulling the pin out make the job whole lot easier.
However, in one of the earlier attempts, I may have broken off one of the the tab keeping the switch in place. After that part arrives, I should be good to go.
Thanks.
Thanks.
