Kenmore canister vac won't turn off
Old 12-12-15, 05:18 PM
C
Please bear with me as this is my first post on a forum.
My vacuum (model 116.2645087) no longer shuts off at the handle switch. I thought the internal switch might be bad and replaced it. No change. Any other parts I should try replacing?
Old 12-13-15, 03:12 AM
pugsl's Avatar
Received 78 Upvotes on 71 Posts
I would ohm the wires in item #1 first. (Hose) next the wires in handle from switch to plug.
HOSE AND ATTACHMENT PARTS Diagram & Parts List for Model 1162645087 Kenmore-Parts Vacuum-Parts | SearsPartsDirect
Old 12-13-15, 10:37 AM
Received 4,151 Upvotes on 3,728 Posts
Does that have a second switch on the canister ?
Does the unit operate with the hose disconnected ?
Old 12-15-15, 09:13 AM
C
It's a new hose. Cannister turns on as soon as its plugged in.
Old 12-15-15, 09:17 AM
C
There is only a Hi-Low switch on the cannister. The power switch is on the hose handle. It turns on when it's plugged in whether the hose is attached or not.
Old 12-15-15, 11:36 AM
I'm trying to find a wiring diagram. It would appear that there may be a stuck relay in the canister part.
That should use Panasonic's three wire hose. (three pin plug at canister)
In the following link.... the part you need to get to is #41. It's a motor control relay and is located near the motor.
Diagram & Parts List for Model 1162645087 Kenmore-Parts Vacuum-Parts | Sears Parts Direct
Old 12-22-15, 09:26 AM
C
Thankyou. I'll give that a shot and let you know what happens.
