Microwave motor
Old 02-04-16, 03:36 PM
T
Microwave motor
My microwave motor is broken and i want to change it. The motor is class E, I found one which is class B. Will it fit? What class stands for?
Old 02-04-16, 03:43 PM
Received 126 Upvotes on 111 Posts
No make, or model # mentioned.
Motor for what?
Old 02-04-16, 03:46 PM
C
Received 134 Upvotes on 110 Posts
Usually, the class refers to temperature rating of the insulation used in the motor windings. Class E is not used anymore, but class B is a little higher than E was. So if the motor is otherwise correct mechanically and electrically, it should be ok.
Old 02-04-16, 04:06 PM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
Wait! Am I reading this wrong? On a chart I found, the lower the letter the less temp rating. Even though the "E" was not listed the "B" rating was rated at less temp than other higher letters. An "E" would be a higher temp rating than the "B" he wants to replace with.
BTW...I agree it's probably not worth repairing.
Old 02-04-16, 04:24 PM
C
Here's a chart that shows E...it is 120C. I agree, it makes no sense, which may be why the system was changed.
https://en.wikipedia.org/wiki/Insulation_system
