Eureka vacuum handle switch
Old 04-10-16, 03:15 PM
G
Eureka "The Boss" 4870 upright vacuum.
The beater bar is not shutting off with the handle in upright locked position. If I push forward on the handle, the bar will stop. So, it seems there is a switch that needs adjustment? My question is where is this switch located?
Also, this vac seems to be making a lot of racket after I installed a new drive belt. The first belt I installed developed a bad spot after only 2 mos of service. I got a belt from a different source this time.
Old 04-10-16, 04:17 PM
Received 3,612 Upvotes on 3,238 Posts
Although I can't locate it in the exploded diagrams..... it's location should be down by the motor. The following link has the exploded views of the vacuum. At the bottom is a repair video that may help you in opening the motor area up for switch access.
Eureka 4870T Parts List and Diagram : eReplacement Parts
Make sure the beater bar is clean and not wrapped with hair and old carpet fibers.
