panasonic 1100w microwave
Old 01-27-18, 02:02 PM
G
When the time ends the microwave keeps running but the heat source stop.If I leave the door open it doesn't run
Old 01-27-18, 06:10 PM
Received 1,036 Votes on 960 Posts
If it's not heating..... what's running.... a fan ? The turntable ?
Old 01-27-18, 06:18 PM
Handyone's Avatar
Is your microwave oven an over the range combination convection/microwave?
When I use my micro-hood in convection mode or combo mode (sensor reheat) , the fan will run for ~5 minutes after use to cool the oven down. It's normal.
Old 01-27-18, 07:35 PM
G
I would say its the fan running you can hear the heat turn off at the end of Time cycle.it is a free standing unit
Old 01-28-18, 10:02 AM
Handyone's Avatar
Please post all your questions in the forums, there may be others with the same problem.
Here's a quote from Panasonic:
After using the oven repeatedly or for long time, the fan may operate to cool the electric components. It is normal for the fan to periodically operate for an additional 2 to 15 minutes after cooking is complete. If the temperature inside the microwave/oven is hot the cooling fan motor automatically operates to cool the electrical parts. This function varies by model and items cooked. You can take out the food from the oven while the fan operates. It is recommended to keep the oven plugged in until the Fan Motor completely stops operating.
Edit: Remove the food and then shut the door, the fan should keep running.
Old 01-28-18, 10:11 AM
A model number of the unit would be helpful.
Old 01-28-18, 01:28 PM
G
The microwave can be off for hours and when I close the door it starts running also the turn table is turning
Old 01-28-18, 01:59 PM
G
IT is called a THE Genius Premier 1100w can't find a model #
