KitchenAid khms2050 repair instructions ...
Old 07-20-18, 08:39 AM
B
I need to replace the control panel circuit board which is in the microwave door ... board prt no WP8206635. Nowhere can I find step by step instructions on how to safely (ie not damage) disassemble the door to access the panel. I have the board on order.
Any suggestions? TIA
Bob
added ... I do believe that I'll have to pry/pop off the inside door surround as a first step ... correct?
Anyone know the size of the tori wrench required to do this job? I was a Xerox tech for many years so accustomed to pc board handling etc etc ...
Old 07-21-18, 12:23 AM
Received 595 Votes on 560 Posts
Yes..... use a putty knife to separate inner and outer door panel.
Old 07-21-18, 09:00 AM
B
Thank you ... I appreciate the hint.
Old 08-15-18, 07:53 AM
B
update ... able to unfasten (from hinges) the door from the unit (as well as the "choke" etc) but unable to locate electrical plug that must be disconnected to allow me to fully remove the door. Surely someone somewhere has performed this task. PLEASE help!
thank you.
