Lg f/load washer stuck on 4 mins....
Old 08-28-18, 12:55 AM
R
I have an lg washer that goes through the normal wash cycle until it has 4 mins remaining on the display, then only the drum will rotate to the left and right and stays at the 4 min on the timer. ???? No error codes on display. Model is number is wm2016cw....
Old 08-28-18, 01:39 AM
pugsl's Avatar
Received 71 Votes on 64 Posts
Been a while since I worked on one. Does the water drain completely? If so may be control board. Here is a service manual to test things. look under troubleshooting.
https://www.manualslib.com/manual/67...page=16#manual
