Kirby Sentria vacuum questions
Old 10-27-18, 06:00 PM
I bought a $200 used Sentria, model G10D from a highly rated seller on Ebay. Vac arrived and after watching many youtube videos, managed to get it set up. The Belt indicator light turns green and i flip it and see the brush spinning smoothly. But when i engage the brush hieght the light goes off. Do i just need a new belt?
ALso when the vacuum arrived there was a bolt of some sort sitting in the box along with a very big light that wouldn't fit a Kirby so the bolt may not even be a Kirby part but i just want to make sure. Its about 4-5 inches long. Vacuum repair guy said it might be for the handle lock but the handle locks.
Thanks for any help
Old 10-27-18, 08:43 PM
Received 4,154 Upvotes on 3,730 Posts
The vacuum cleaner that polishes, steam cleans, spray paints and even vacuums. Leave it to Kirby.
That could be indicative of a slipping belt.
I did not find that pin in any of the pictorials or parts lists.
Some helpful links below......
Owners manual PDF
Replacement parts with diagrams
