I have a Samsung that has microwave, convection oven, fry, grill and combinations of these.
About 2 months the fuse blew when trying to start. Replaced fuse and all worked again but started smelling a burnt smell. Well, the fuse blew again last night when starting microwave feature. I unplugged it last night and removed the top today. I saw no burnt wiring, but noticed a brown spot above the fuse on the inside of the top. Removed fuse and could smell burnt smell. Took fuse to another room and could still smell this.
I could replace the fuse again and see if it works, but don't want the burnt smell. I read it could be fan or not worth fixing. A replacement would be around $300 new.
I would like to send a picture of something that looks strange also.
I'm installing an over the range microwave (Frigidaire) and wondering how to do the paper templates. Hopefully someone can give me some pointers.
I have the back wall template in place. Pretty easy, no big deal.
The upper template, according to instructions, needs to be cut to fit flush up on the underside of the cabinet (there is a small trim piece going all the way around the underside where the top of the microwave will sit).
It's the cutting the template that gets me. It seems that I CAN cut the sides and the front of the template, but the back (wall) side of the template should NOT be cut because that will affect where the holes are. Any pointers on this?
I was also thinking that I could sit the microwave on the wall plate, go ahead and screw the bolts in about halfway on top, put some caulk on them, and then push the microwave up to touch the underside of the cabinet and drill the holes where the caulk touches.
I hope this makes sense, please let me know if you need pics. Many thanks!
