Sharp R-8290 Microwave Blowing Fuse Immediately
Old 08-09-19, 01:23 PM
DPDISXR4Ti's Avatar
This is a 1988-manufactured oven, so it certainly does owe me anything. That said, if I can fix it for short money, I will.
The other day, it just shut off during use. I replaced the fuse, display lights up, I can set the time, open and close the door, but the second I try to run it the fuse blows. From what I've read, this points to the capacitor as the likely fault. I measured the resistance across the terminals and there is none - i.e. complete continuity. Have I found the problem?
Thanks...
Old 08-09-19, 02:15 PM
Received 916 Votes on 856 Posts
If there is no short measured across the cap.... then it's not shorted.
Check the high voltage diode.
Old 08-10-19, 11:05 AM
DPDISXR4Ti's Avatar
Thanks for the reply Pete. I'm saying there IS a short. There is no resistance at all between the terminals of the cap - complete, no resistance continuity.
Old 08-10-19, 11:16 AM
Yes.... there is a resistance. If you have a dead short.... you would have 0 ohms or possibly 1 or 2 ohms.
An open circuit is no resistance.
Did you measure across the cap with the wiring or at least one wire removed. I believe there is a bleeder resistor on the cap but it should be very high resistance.
Old 08-11-19, 09:43 AM
DPDISXR4Ti's Avatar
Okay, my bad on the terminology. Indeed the cap is dead-shorted. For this oven, the resistor wire is on the harness side.
I just am on the fence about bothering to invest even $20 for a new capacitor. It is a 31 year-old appliance.
