In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Hoover Steam Vac Brushes Wonít turn
Old 09-18-19, 07:36 AM
I have a Hoover Steam Vac Deluxe Model F5680-900 and I just noticed that the brushes will not rotate. I removed the five brush assembly and can manually get the brushes to turn. However, when I turn on the unit with the brushes removed, I do not see the square hole adapter (that the brush assembly connects to) turn. It has two speeds and doesnít work in any position.
when I try to turn the square hole coupler using a screwdriver, it also will not turn.
Does anyone have any experience as to what the problem might be?
Old 09-19-19, 10:10 AM
Received 932 Votes on 869 Posts
I'm trying to look up service info and don't see that model number listed.
Can you double check it ?
Did you mean......F5860-900 ?
If yes..... you would need to replace the....
Turbine And Gear Assembly - 5 brush. Replaced by 43191019
You can use this part number and find it at many retailers including amazon.
Old 09-19-19, 10:58 AM
Yes you are right. I transposed two numbers. It is 5860-900. Thanks for your info. I found a video on YouTube that shows how to remove and disassemble this part. So iíll take it apart and see what might be wrong before I order a new one.
Old 09-19-19, 11:29 AM
Good thinking. Many times it a rusted/frozen bearing. Let me know how you make out.
Old 09-19-19, 03:02 PM
Yes the bearing was rusted and frozen. After cleaning everything up, I found the bearing was missing half of the rollers. It should be replaced but I doubt it can be purchased separately. I went ahead and greased everything and tried it and it worked. However, after reinstalling the top cover, it wonít work. Remove the top cover and it works. Havenít been able to figure out why the top cover is preventing it from turning. Will look at it again tomorrow.
Old 09-19-19, 06:55 PM
If it's a ball bearing and half are gone.... the shaft won't stay centered.
The impeller may be hitting the cover. Not something you'd be able to see.
