Bissell Little Green
Old 05-05-20, 09:03 AM
B
I have a Bissell Little Green Pro Heat Pet steamer. I am experiencing no spray and low suction. The nozzle attachments are clean so that is not the problem. Any suggestions would be appreciated, thanks.
Old 05-05-20, 10:26 PM
Received 923 Votes on 862 Posts
The spray and suction are two different areas. The only thing they share is a common hose.
Has the hose been stepped on or damaged ?
Old 05-07-20, 05:52 AM
B
Yes, I see the that the spray and vacuum hoses are inside the larger hose where the attachments go on.. But I can't figure out how to remove the outer hose to check for damage or plugged up areas. Thanks
