Microwave trim removal
Old 05-17-20, 11:53 AM
Hi, It's time to replace the microwave, I'm assuming trim has to go first and 4 screws were removed, one from each corner. But the trim flexes and bentd but not moving.
Any suggestions?
Old 05-17-20, 01:39 PM
Received 923 Votes on 862 Posts
More than likely the trim is also attached to the microwave so that it all comes out in one piece.
Old 05-17-20, 02:01 PM
XSleeper's Avatar
Received 576 Votes on 529 Posts
I would begin by removing the 4 screws on the corners of the trim.
Old 05-17-20, 02:05 PM
He did that.....but the frame did not come out.
Old 05-17-20, 02:07 PM
XSleeper's Avatar
Oh yeah. Then I have nothing to add. LOL.
Old 05-18-20, 03:41 AM
Received 147 Votes on 134 Posts
A model number would be useful If you can find it.
Old 05-18-20, 01:18 PM
Here you are, this show all information. Thank you.
Old 05-18-20, 02:11 PM
Below is what I think is the trim kit install sheet.
Hopefully it will help you uninstall it.
https://www.whirlpool.ca/content/dam...ns-4386554.pdf
Old 05-18-20, 06:25 PM
Based on that trim kit instruction sheet...... nothing but the four screws are holding the front trim on.
That would mean it would need to be carefully pried out. Probably in the corners.
Another way would be to take a piece of coat hanger and bend a small hook on it.
Put the hook in the grill to grab the front edge to pull it out.
Old 05-18-20, 06:41 PM
Also it looks like 1/4 round was applied around the trim kit.
Perhaps it was installed with the paint not totally cured so it may be stuck to the trim kit.
Run an exacto knife around the between the trim kit and 1/4 round.
Old 05-19-20, 04:48 PM
Thank you. Yes I did try to ago around with a blade. May be I need to cut deeper...
Old 05-19-20, 05:02 PM
XSleeper's Avatar
Or remove the quarter round entirely.
